NDS II Not working on K11 OBD2 CGA3DE and CG10DE
Jeroen330
Post by Jeroen330 »
Hello Guys,
I've posted this before and doing it again because this problem is very anoying.
After 4 years of using NDS I on Nissan K11 OBD1 vehicles i bought the NDS II kit.
In the description it also said:
March K11 2000-2002
The software works perfect on OBD2 nissans.. I've tried the K12, the P11-144, but the OBD2 K11 just WON'T work... :cry:
Thing i can do with the software:
- Read out fault codes
- retrieve and clear fault codes
Things i can't do with the software:
- Adjust timing
- Adjust Idle
- Open Data display
- read out sensors
I hope you guys can solve out this problem because i am i need to get these features working!!
Please reply
Jeroen330
Re: NDS II Not working on K11 OBD2 CGA3DE and CG10DE
Post by Jeroen330 »
Something not working with a wrong ECU ID?
How can i find the working ID for the CGA3DE and CG10DE K11?
Are you reading the error codes from the ECM or OBDII tab?
When you say you can not "open Data Display" window. Is it because the Data Display button is greyed out or the Data Display window doesn't display anything.
Jeroen330
Post by Jeroen330 »
I am working on the ECM tab..
the OBD II tab only displays one parameter at the time and i want to see more so i can compare..
I have now a data display figured out inside the settings.. some sensors cannot display so thats why the program didnt show..
Ecu ID = 10
Now i have the problem i cannot adjust idle or timing. The buttons are grey on the screen so they won't work.. I need them working for some idle adjustment..
Can you help me out tom?
The NDSII checks for ECU functions when it connects. If the buttons are greyed out that means the ECU doesn't support those functions.
