ELM 327 WIFI
deviennet
ELM 327 WIFI
Post by deviennet »
hello
I have a nissan Primera that apparently and according to the garage has a problem with the distributor :shock: strange ... anyway. I would like to connect my smartphone to my primera via an ELM 327 in order to read error codes and fixing it / them my self. does the ELM 327 WIFI works with NDS I an II.
Is the lite version of the app read the errors and shows the timing
Re: ELM 327 WIFI
ELM 327 over WiFi is not supported. Only Bluetooth. And USB in case of NDSI app.
Yes, the lite version can read error codes.
deviennet
Re: ELM 327 WIFI
Post by deviennet »
thanks for your anwser Tom.
any work around since the windows version does not support ELM adaptors as mention on your website?
Thomas
