Hello all,
still trying NDS before buying...
Now my prob: I can connect to the ECM (id 0x10) and OBDII (same). However any other ID is a no go (default). So, is there a list/website/nissan information for me to try and adjust the settings? I purchased a VAGCom KKL adapter and adjusted the comms settings to recommended. Still it only finds ID 0x10 for active ECUs.
Any thoughts on this issue?
Ta, Axel
ECU IDs
Re: ECU IDs
Sorry, forgot to mention:
Primera Sport Saloon 1.8 16V 2000 (X-Reg) QG18DE
Ta, Axel
Ta, Axel
Re: ECU IDs
Have you tried the "Find ECU" function under Settings->Communication? This will show if any other ECUs are available.
Probably the other ECUs are using the older Consult I protocol for communication that’s why you can not connect to them.
Re: ECU IDs
Hey Tom,
that's what I have done already. And it only showed ID 10.
So, if the others are using Consult1 how can I connect if there is only an OBD2 connector?
Ta, Axel
Ta, Axel
Re: ECU IDs
That means you can not connect to any other ECUs over the OBDII k-line. You can not change anything in the software to fix that.
