fuel trims?
3pointedstar
fuel trims?
Post by 3pointedstar »
hi
I am running a JDM Z33 and I would like to monitor/log my fuel trims. However since I am on a JDM ECU I cannot use the OBD2 tab. I also noticed that the fuel trim option is missing from the drop down list under the ECU data monitoring tab. Is this a limitation of the JDM ECU or DataScan?
Cheers!
Re: fuel trims?
The fuel trims on this ECU are called "A/F Alpha" for short term and "A/F Alpha stored" for long term. b1 is for cylinders in bank 1 and b2 for cylinders in bank 2.
