NDS CONSULT functions mostly don't work
rwp728
Post by rwp728 »
I purchased the latest DataScan II software for use with a generic adapter on a 2000 Altima SE.
(Ordered 11-2-13, receipt number is 4432-3341-4855-7377.)
The software connects and the OBDII functions work, but the Consult functions are mostly grayed out. It shows ECU S/N 23710-0Z812, Software version 0x00.
The ECM Data Display Settings showed no choices, and Active Test, Cylinder Power test, and Work Support showed all functions disabled. The Data Display settings also show no choices for the boxes.
I tried changing the "ini timer offset" setting, and also DTR checked / not checked. These made a difference in the connect time, but no difference in the Consult functionality.
Can you tell me how to get the Consult functions working on DataScan II?
Re: NDS CONSULT functions mostly don't work
US Altima 2000 - requires Consult I adaptor with OBDII plug and NDSI software
