invalid port number?
Posted: 26 Jul 2013, 07:51
by gabrielflrs
Hi!!! All of my drivers are updated and when I plug the cable in then open up NDS, I get a pop-up saying invalid port number. My laptop is not even a year old. Can someone help me on this topic? :?
Re: invalid port number?
Posted: 04 Aug 2013, 09:18
by seb.racing
hi
you configure your port com?
7. I'm trying to connect to my car's ECU but I get an error message "Invalid Port Number".
The COM Port number that the NDS I software is trying to use is invalid. If you are using an USB adaptor or USB to serial converter, a COM Port number was assigned to your adaptor by the driver at the time of first installation. This COM Port number will need to be entered in the NDS I software under Settings->Communication.
If you don't know what Port number was assigned to your adaptor you can find in Device Manager under "Ports (COM & LPT)".
Please note: NDS I will only work with Com Port numbers 1-16. So if your adaptor has a Com Port number above 16 change it to something lower first. You can do it through Device Manager by going to Properties->Port Settings->Advanced.
