Hello forum members, I have a question about these data scans. I only have 1 Intelligent key for my 2008 Nissan Altima. I purchased a second intelligent key from Ebay and it has an uncut key inside. If i want to program the remote part, can the datascan II do it?
Thanks in advance
INTELLIGENT KEY PROGRAMMING
Re: INTELLIGENT KEY PROGRAMMING
Probably not.
The NDSII software can program the transponder keys but not the intelligent keys.
seb.racing
a question, the PIN code is or what? on the key or it must ask Nissan
thank
thank
The PIN is stamped on a little metal tag attached to one of the keys. If you don't have the tag you can get it from your Nissan dealer.
seb.racing
ok, the metal plate provided with two key
SilverAero
Hello forum, to the makers of the nd2 is there any plan to add intelligent key programming, im planning on buying one for my 2007 nissan cube which it appears should work but i would like to have that feature.
Dears
i have metal plate but it have 6 digit starting with S
Sorry, there are no plans to add intelligent key programming at the moment. Maybe in the future.
If you don't have 4 digits on the tag you will need to take it to the Nissan dealer to get the immobilizer PIN.
