03 Infiniti FX35
Posted: 22 Jun 2013, 21:23
Hello all,
I am new here.
I own a '03 Infiniti FX35 and i downloaded the NDS II v2.52 to do some fault finding on my car.
As i don't have a licence yet, i just tried to communicate with the car trough my Blazt II OBD2 connector and it does work.
I know that not all functions are working as it's a non registered product but before i purchase a licence i have a few questions.
I am able to connect to the ECU, ABS and OBD2 interface, as it's showing the ECU part numbers and says it connected.
But i can not connect to the BCM, TCM and SRS interface, is this because of the limitation of the non registered version or is this not possible at all?
Before i had NDS II v1.3 and this was only able to retrieve the fault codes on the engine manengment.
Does v2.52 also retrieve the fault codes for the ABS etc. or will this still be limited to just the engine ECU?
Hopefully you guys have some experience with this combination and are able to tell me when i purchase a licence i have full access to all functions and fault code retrieval.
I am new here.
