1998 Pathfinder R50
system-f
1998 Pathfinder R50
Post by system-f »
I am slightly confused and this is more for curiosity. The website says the datascan II works with my 98 R50 with the VG33E and I guess this is through the OBDII port? I also have a 14pin Nissan Consult port so will DataScan I work with my vehicle?
Regardless, I have followed the websites instructions and ordered one of the compatible OBDII to USB interfaces and will then test the software.
One thing I noticed on the compatibility webpage is that the R50 is listed as having the VG33DE and VQ35DE. I think the VG33 only came as an "E" (VG33E)as it never had dual overhead cams from the factory, but maybe there is something non-USD I do not know about?
Thanks again
Re: 1998 Pathfinder R50
I would recommend you use the NDSI and 14pin adaptor. This would give you a lot more data using the Nissan Consult I protocol.
The OBDII connector is probably only for very basic diagnostics. In Australia even the 200x models VG33E cars didn't have fully implemented Consult II protocol.
system-f
Post by system-f »
What adapters will work with the 14pin connector?
PLMS adaptors are good and reliable.
http://www.plmsdevelopments.com/consult_if.shtml
