Ok, I have download the NDS1 and test it out to start off. It work perfect, just without the full function. What I mean is, it connects to my rb25det when the car is turn on and even starting the car. No problem. So I purchased the program, and now the frozen happening. NDS1 connects when my car is turn ON, and when I crank start my car, the program freezes. WHY?? I've tested with 2 of my laptop and its doing the same thing. Would be appreciated if anyone can help.
I've install new drivers, activate the program on different laptops, doesn't work. =(
Recently Purchased and activated. Freeze!!!
Re: Recently Purchased and activated. Freeze!!!
this is the gauge that blocks?
this is normal, the communication is cut at startup
you close the window the gauge and you open a new
Thanks for reply. So this is normal??
I've tried the program when it was free. But when I start up, the communication didn't get cut. I can see my rpm running in NDS1. Now after I registered, it won't.
Sorry, I don't understand. you said close the window the gauge and open a new. What does it mean? Please let me know.
