Early Tino compatibility
highlea
Post by highlea »
I want to buy NDS for use with a 2002 Almera Tino V10 with SR20DE engine.
I have used a simple OBD scanner to read and reset error codes, but when using a more sophisticated T300 unit, which can read sensors on other vehicles, it was still only able to read errors on the Tino.
I also borrowed a friends bluetooth unit, running Torque app on an Android device. It was only able to monitor Coolant Temp and Engine load on the Tino.
Can NDS read more channels from this ECU? What is available? I know the Tino went through a major upgrade in about 2003.
I currently have a problem with mixture, probably caused by a faulty knock sensor, so need to see fuel trim values.
Thanks Colin
