NEW NDSI function
onephatser
NEW NDSI function
Post by onephatser »
Any possibility you might be able to implement a program so that I can see what my oxygen sensor that's in the catalytic converter is reading as far as voltage?
Re: NEW NDSI function
What gauge options do you get when you go to Settings->Data Display ECM?
onephatser
It gives me O2 sensor bank 1 sensor 1 and WBO2 sensor. I need O2 sensor bank 1 sensor 2. This function is not supported with NDS1.
onephatser
The catalytic converter sensor is not supported with NDS1. Is there a possibility that this could be implemented? The whole reason I bought the software was to be able to read that sensor.
seb.racing
Post by seb.racing »
yes, the O2 sensor is supported by NDS1
you must go to Data Display Setup
selected O2 sensor
onephatser
It does not work for the sensor in the catalytic converter.
seb.racing
This is what car?
onephatser
1998 Nissan 200sx with the SR20DE engine.
seb.racing
you have an O2 sensor before and after the catalyst
try the Live Register Test
normally the NDS1 has fontion for both O2 sensor
http://home.exetel.com.au/nds/NDSI/pict ... ogging.jpg
onephatser
It does in fact support the rear oxygen sensor. The parameter for it is oxygen sensor B1.
