USB1.0 support
edwardtx
USB1.0 support
Post by edwardtx »
Does it support USB1.0? Reason I ask is because I have an old laptop with USB1.0 that I'm trying to use Datascan in my garage. I have installed but it does not connect.
Re: USB1.0 support
Yes it does. It's depended on the driver but the FTDI drivers support USB 1.0.
Does it come up with a Com Port number in Device Manager?
edwardtx
Re: USB1.0 support
Post by edwardtx »
Ah, that's one thing I haven't checked. Let me check on it when I get home from work this evening, will sure to report back. Thanks.
edwardtx
Re: USB1.0 support
Post by edwardtx »
Com1 is open but still can't connect.
Re: USB1.0 support
Does Com1 disappear from Device Manager when you unplug the adaptor?
I ask because usually Com1 on older PCs is the serial RS232 port.
edwardtx
Re: USB1.0 support
Post by edwardtx »
Got it to work finally! I had to manually update the FTDI driver for the COM port.
Thanks for all your help!
mgh
Re: USB1.0 support
Post by mgh »
Yes my com1 disappears when I unplug the adapter, what would be my next step to finding the RS232 port.
