USB Download
DiverDave
USB Download
Post by DiverDave »
Hi again ;
I read somewhere there was a download for the USB driver to work with the Data Scan II cable
But I have not been able to find it , on this site or anywhere.
Maybe there should be a dummies download area where everything you may need can be found in one place.
I am still unable to use this cable and am getting fed up with having to sit in the heat trying to make it
all work.
Some help .. or an air con would be nice ;p
DiverDave
Re: USB Download
The driver is available from our download section. Scrol right to the bottom of the page. Below is a direct link to the download section.
http://home.exetel.com.au/nds/NDSII/ind ... t=download
You can also use the drivers available from the FTDI website http://www.ftdichip.com/Drivers/VCP.htm
DiverDave
Re: USB Download
Post by DiverDave »
Thank you for the two links .. I'll be able to get things rolling soon ..
The download I found with a google search is at 97% done .. its slow
and has been working for hours now ..
But I'm sure I can get the drivers in just a minute or two with the links you just provided .
I'll let you know if everything works :)
Sure wish I got a CD with all the possible things I needed when I payed for all this.
Thanks again.
DiverDave
DiverDave
Re: USB Download
Post by DiverDave »
The first driver from this site worked and now I can make connection with the computer.
Thank you for your help in this matter.
DiverDave
