QR25DE Tuning
ECU dumps, maps, ROM files, log files and tunning discussions
Re: QR25DE Tuning
Let us know how you go and if you are able to identify any maps.
murphys_law
Re: QR25DE Tuning
Post by murphys_law »
I'll be sure to update on progress. It seems I have much to learn. I don't have a computer programming background only industrial controls.
EDIT:
I looked around in the MAxima rom tonight and found the cam timing. I have another thread about it. I'm going to start looking at the spec v rom soon as I just pulled it tonight as well.
murphys_law
Re: QR25DE Tuning
Heres a copy of the box stock spec-v rom. I haven't looked at it much yet.
18U07A-20160617-225603.bin
02 Spec V USDM Fed emission
(512 KiB) Downloaded 3079 times
murphys_law
Re: QR25DE Tuning
To do a little updating. I've helped to decode a few roms over on the rom raider forums and have successfully flashed my 02 maxima and 02 sentra spec v, along with my 06 g35 6 mt(cam timing, rev limits, fuel comp, etc, maf, and timing maps I have found.) The sh7055 ecus all use the same basic code structures and its not too hard to find everything. The sh7058 in my g35 is also very similar, but I'm having a hard time figuring out the rev limiter. My rom is 90% or so similar to Ak eyes rom posted above. Anyone have insight in to how the later nissan ecus handle the rev limiters? Its more of a soft limit compared to the earlier roms, so I'm assuming the logic is different.
1CM31C-20160617-121232.bin
(1024 KiB) Downloaded 3522 times
murphys_law
Re: QR25DE Tuning
> different.
Bump to this. Later sh7058 use both fuel cut and thottle cut for Rev limiters. I see this now doing more research. I'm fairly confident the fuel cut works in the same way as the earlier cars, however the throttle cut(closing) is something that I don't have a handle on. Anyone?
moldbruja
Re: QR25DE Tuning
Post by moldbruja »
so im posting some deffinitions for 2002 spec v ecuflash usefull ill like to get help idntifying some on the maps in this deffinitions
8U523.xml
(16.82 KiB) Downloaded 2618 times
moldbruja
Re: QR25DE Tuning
Post by moldbruja »
2002 non nats ecu deff
8u023.xml
(18.14 KiB) Downloaded 2641 times
moldbruja
Re: QR25DE Tuning
Post by moldbruja »
7200 rpm rev limit bin file 2002 specv brand: cant be named
8U523.bin
moldbruja
Re: QR25DE Tuning
Post by moldbruja »
Could 5e5d and 5e0d be afr target open and closed loop tables???
moldbruja
Re: QR25DE Tuning
Post by moldbruja »
please feel free to add or correct any table on this deffintion!! ill like to get a full deffintion just like subaru,s in ecuflash!!!
8u523.xml
(18.69 KiB) Downloaded 2619 times
