NDSII for Android released
gilbr
Re: NDSII for Android released
Post by gilbr »
Hi. Sorry for my english, it isn't good.
I have a nissan 2012 sentra se r spec v and a 2014 nissan versa. May I know if the android nds have support for these cars?
Regards.
Hi gilbr.
Your cars are probably using CAN protocol for diagnostics so NDSI or NDSII will not work.
We are currently working on NDSIII that will support CAN cars. We are hoping to release it before the end of the year.
Rubengr
Post by Rubengr »
Rubengr wrote:
> Hi tom . I've attached a screenshot of the connector leading our cars. I
> guess all Nissan OBD connectors carry the same wiring configuration . If
> you need additional information , I am at your disposal .
> Thank you very much and best regards .
Sorry Tom. If my 16-pin connector is but the pins correspond with DDLI, because in the book of car workshop always talk Consult II? He never talks about Consutl I.
The Consult II tool is a later generation tool but backwards compatible with Consult I protocol. It can "speak" both Consult I and Consult II protocol.
vanhack
Post by vanhack »
Tom if NDS II android version is backwards compatible, then it should be able to talk to the TCM and any other Consult I modules on a Nissan Patrol TB48E ?????
I thought that NDS II was only consult II and hence could not access the TCM or 4WD modules.
The NDSII software is not backwards compatible.
The Nissan Consult II tool is.
Spannerdemon
Post by Spannerdemon »
Tom, if you still want a non compatible /problem, v2.1 adaptor, You can have mine. I emailed you about my problem yesterday.
Let me know where to send it, and it's on its way. No charge. If it helps you, me and others, great.
Keith Simpson. UK. Nissan Elgrand VQ35DE V6 engine.
Thanks for the offer.
We do have one of those adaptors. It's a dodgy firmware. It's not an genuine ELM327 chip.
