Primera P12 ABS connection
Re: Primera P12 ABS connection
These diagrams are showing a k-line connection to the ABS ECU pin 11. NDSII should be able to connect to it if this is your ECU.
muhamad yunos haron
Post by muhamad yunos haron »
what is ecu id 72
muhamad yunos haron
sorry what is ecu id 71
Not sure what id 71 is. Did you get the ECU number for this id?
Did you try changing the "Ini Timer Offset"?
muhamad yunos haron
my car is x trail t30 series 2 QR25DE
My ecu test got this result
ecu id 10 - active (ECM)
Ecu Id 22- active ( 4WD) - checked with other software ( car gauge pro android )
Ecu Id 28- active ( ABS)
Ecu Id 58- active (SRS)
ecu Id 71- active - ( change TCM ecu Id from 18 to 71 and got connected with the ecu part number 31036-EQ4A)
I'm using the unregistered version on NDS 2 and I cannot confirm if it is actually TCM ecu connected.
Can Tom or anybody confirm.
tq in advance
muhamad yunos haron
Sorry got connected to TCM with ecu ID 71 result - ECU PART NUMBER : 31036-EQ40A, SOFTWARE VERSION: 0x803
muhamad yunos haron
Does this means that Nissan Xtrail t30 qr25de series 2 is using k-line protocol for accessing the TCM ecu?
Anyone can help me confirm ti his before I purchase NDS 2.
