V41 Quest/Villager
mikeluscher159
Re: V41 Quest/Villager
Post by mikeluscher159 »
Is that a 16 pin?
The pictures aren't clear
If it is, and you guys think it'll work, Sold!
It's a 14-pin.
mikeluscher159
Grr :(
I guess I'm just gonna have to bite the bullet on this, when I have the $$$
$165 for a one vehicle diagnostic system...... What a world
Edit: I did try a $9 VAG-COM cable for the fun of it, Got some info like timing and idle and trouble codes on NDS-II and I, but it was an inconsistent connection.
What tab did you connect from? Was it the ECM tab?
What do you mean by "inconsistent connection"? Did the connection drop out while running in the Data Display form?
mikeluscher159
I connected through the ECM tab once I Think
OBD-II worked as well
It's been a few weeks since I did it, Tomorrow I'll give it all a run through once more for a precise Works/Don't work list
That adapter and licence is still gonna sting real bad.....
But in the name of science! :lol:
If you can connect with the VAG COM adaptor from the ECM tab don't buy the Consult I adaptor. It's one or the other.
mikeluscher159
Then this works
A Blue VAG-KKL USB adapter into my 16 pin connects in NDS-II under ECM
ECU # 23710-2Z301 SW # 0x475
Now ECU and OBDII work because this is the limited version of the software?
But won't connect to anything else
SRS, ABS, TCM, and Full ECM will light up in the paid version?
Again, thanks for the patience in explaining this all out to me.
Diagnostics in This Ford/Nissan Crossbreed never cease to confuse me
I'm more used to CANBUS Ford's with FORScan
Shame the ISO9141-2 Abilities of my new OBDLink MX can't be put to use with this software. It's ELM backwards compatible, but does a lot more then a clone ELM327
skylinegtrhr
Post by skylinegtrhr »
So it will be reverse of this cable:
http://www.banggood.com/OBD-to-ODB2-Rea ... 25024.html
mikeluscher159
No. '99 and newer V/Q's don't have a 14 Pin Consult connector
My '01 as I see it, is doing Consult over a Consult 2 system
