Hello,
I'm just looking into some mobile software updates and getting a bluetooth obd adapter. I have been reading about the NDS II software.
What I can't find confirmation about is....does the Android version just read the ECU ? or can it do exactly everything the Windows version can? read BCM, TCM, SRS, ABS etc etc?
This would be the deciding factor on purchasing this software for me at this point.
*Edit*
I have found in a different thread back in May that it was stated all PC functions were not implemented in this Android version....has this changed since?
NDS II Android Functions vs. Windows Version ?
D40FrontierNA
Re: NDS II Android Functions vs. Windows Version ?
Windows version has more functionality. The Android app supports ECM (Engine ECU) functions: Data Display, Self Diagnostics, Clear Self Learn and Idle Air Volume Learn. Other ECUs are not supported by the app.
Hi All! Does key programming work on Android version?
Immobilizer key programming is not supported by the Android app.
Hi there. I'm using the windows version for several years now and I was expecting the Androïd version for a while... Unfortunately this one is not supporting the immobilizer function ! I've an issue with this in my car and it's the reason why I use the immobilizer key programming... Is there a chance to get this function on the Ancdroïd app ? It will prevent me to carry a PC in my car all the days...
