I can connect to the ECU, though I have to search for it every time I hook up before it will actually connect, and I can connect to the OBDII, but no matter what I try adjusting, I can't connect to the BCM. Any ideas?
I'm unable to connect to the BCM
Re: I'm unable to connect to the BCM
What is your car and what year? It could be that your BCM is using the older Consult I connection.
twscaptain
It's a 2002 Sentra ser specv
Is there actually a BCM on your car or just the Smart Entrance Control Module?
twscaptain
I'm not 100% sure, and I'm not sure where to look to confirm.
The Smart Entrance Control Module on those cars uses Consult I connection with Rx and Tx lines. Those will definitely not work with NDSII. I can't really find any reference to BCM in the wiring diagrams.
Do you have any specific reason why you are trying to connect to the BCM?
