350z Imobiliser Key Program
cs2000
Post by cs2000 »
Hi there, was just looking on your site and about to make a purchase of the software when I realised something.
I have a blank key bought online which I have managed to get to unlock the doors on my 04 350Z, however it does not start the car due to the immobiliser chip. The seller stated the chip was erased and ready for programming so I found your video online showing how this is done using the software http://www.youtube.com/watch?v=SmQsR1rqUfA I see you enter a 4 digit PIN code which I take it is the NATS PIN.
The three keys I have are the remote key that came with the car and one dumb metal key with a key-tag with a 5 digit number on it and my new remote key I want to program. Is this the code on the metal tag the one I should enter into your software even though its 5 digits and not 4?
If this is the case il probably put an order in within the next few days but since this is the sole reason I need the software I want to make sure it works first!
cs2000
Re: 350z Imobiliser Key Program
Post by cs2000 »
Or, does anyone have a UK Nissan car that can find the BCM serial, heres a photo of mine, but no serial number in sight, these are all generic model codes and such :(
I know this is 100% the BCM aswell, its in the drivers foot well just below the fuse box.
http://i142.photobucket.com/albums/r103 ... _21961.jpg
You are correct. I can't see the serial number on it either.
cs2000
Post by cs2000 »
Thanks for the reply, Did I read somewhere you had a 350z?
Still, from what I understand your Australian and you drive on the left hand side of the road too so your cars should be built the same as UK cars essentially.
The US BCM's are on the other side of the car with a totally different sticker, im gonna have to pull that side apart tonight, see if they left the sticker there for some reason.
