pressure sensor intake 200sx S14 SR20DET
seb.racing
Post by seb.racing »
hello
I have a question on my SR20DET
I have a pressure sensor on the intake air duct
but the NDS gives no function used for the sensor information
is there a manipulation for the NDS uses this information?
thank
Re: pressure sensor intake 200sx S14 SR20DET
No, sorry. The NDSI software can not monitor the boost sensor. It might be possible to add it in the next software release.
seb.racing
ok, yes it would be great if you can add the function
+ Function airbag and abs
you have a lot of work for the next release :mrgreen: ;)
I've got the Air Bag and Diesel support almost implemented. I will release it once is done and tested.
ABS support will take a little bit longer.
seb.racing
strongly the new version :D
seb.racing
I have a question about the information the boost sensor
What is the unit of measure?
If I remember correctly it's voltage.
seb.racing
voltage in mV?
because, the display is minimum 0 and maximum 250
seb.racing
the unit of measure could be the kPa?
250kPa ≈ 2.5bar ≈ 36psi
What readings are you getting? Does it go above 5.1?
