Hi to All!
Just want to thank Tom for his good work!
I have a question for displaying graphs.
Nissan Maxima A32. When I viewed in the mode "Log Analyser" will not show some of the parameters (in graphical mode). Although you, in Data Replay" I can see their values.
Why is this?
BR,
Trouble with Data Replay?
- Maxima12.log
- Log-file
- (32.43 KiB) Downloaded 398 times
- A comparison between data display
- maxima_a32sum.gif (47.13 KiB) Viewed 5175 times
Re: Trouble with Data Replay?
What version are you using?
The O2 sensor is the green line at the bottom. It doesn't chnage in your log so it's just a flat line.
The Air Flow didn't show on your graph but it ame up fine on my ver 1.62.
[attachment=0]MaximaLog.jpg[/attachment]
- MaximaLog.jpg (157.23 KiB) Viewed 5172 times
Hi!
Tom, thanks for the reply.
To view this log I'm using version 1.62
Yes, this O2 sensor is "tired of living", but my question is: why is it data (31) displayed a line of zero (as the line for MAF-sensor)?
BR,
BR,
I have understood what it was. After the first cell of the column data of the sensor I replaced a value of 31 to 1. And his line signal "rise above."
And the graph has become like others.
Thank you Tom.
All the best,
Off. I''m sure that your both NDS and future diagnostic scanner has a large reserve of your PC-based Scan Tools "promoting market" and I will make suggestions...
BR,
Thank you Tom.
All the best,
BR,
OK, I know what you mean know.
Yes, the Data Display function scans through all data for each parameter. It then sets the lowest value at the bottom of the graph and the highest at the top. So if for example the log contains only RPM between 5000 and 6000 the 5000 values will be at the bottom of the graph and not 0.
