NDS3 with Y62 Patrol
Discussions related to Nissan DataScan III (NDSIII) Windows PC software.
MrTorino351
Post by MrTorino351 »
Before I buy a cable, can anyone tell me if this will work with a Y62 Patrol
Cheers
Re: NDS3 with Y62 Patrol
NDSIII has not been fully tested on Y62 Patrol yet. We will have some testing done very soon, hopefully in a couple of weeks.
MrTorino351
Ok cheers. I purchased a cable that you guys recommend for NDS3, and will just give it a go.
I did try with NDS 2 and the Blatz cable from my 4.8 and could only access the air bags I think it was, or the abs.... I can't remember.
Really hope it works
Let us know how you go. We can work with you to resolve any issues.
MrTorino351
Cheers mate. Will have the cable next week and will let you know what happens haha
MrTorino351
Hey mate, yes it works.
Can I ask what limits the amount of options you can adjust within the car?
I know consult can do a hell of alot of things, do you limit the amount you can do for waso of use for people? I need to access more things in the car
When the software connect it checks which options are supported by the ECU. If the ECU reports that they are not supported the option is disabled in the software.
Some options like adjustments have limits set in the ECU software. For example, the ignition timing adjustment can only be adjusted by a few degrees. How many degrees is hard coded in the ECU software.
What things did you want to access that is available in the Consult software?
MrTorino351
I'm wanting to access things like
Tpms System
Headlight levelizer settings
Just generally as much as possible hahah. I have seen someone using consult at Nissan on YouTube and you can do a lot of things that aren't in NDS.
Was hoping you kind of just chose a few main features and left alot of the obscure stuff hidden so people didn't stuff anything up haha
MrTorino351
You have a heap of customers waiting to buy this software if you could do tpms with it. Being 4x4s we often change tyres/wheels for on road and off road. And also, not being able to rotate tyres and reset tpms location is very frustrating.
cocobug
Post by cocobug »
thats true, also an option like rev limiter removal (cutoffs) will be very nice and easy implantation into the software
