Hi.
I appreciate this car isn't on the compatible vehicle list, but will it appear any time soon?
Edit:forgot to add it's a jdm market model 1997
Nissan Stagea Wc34 Rb25det series 1 compatibility
Re: Nissan Stagea Wc34 Rb25det series 1 compatibility
Are you asking if NDSI software is compatible? Or you want it to be added to the list?
> to the list?
Hi.
I tried to connect with NDSI and it couldn't find the cars ecus. I clicked find ecus under the connection tab and it did a full scan but nothing found.
If it could be added to the list that would be great, happy to pay for full version etc
> to the list?
Hi.
What adaptor are you using? The NDSI software should work fine with your car.
I've tried about 10 leads that I've got lying around from various different softwares.
The only lead that doesn't come up with a com port fault is in the attached picture.
I've been trying to find some info on the white with fix but all of the pictures have disappeared
- 20211021_122654_resized_1.jpg (191.6 KiB) Viewed 38234 times
You are using a VAG cable with 16-pin to 14-pin converter. That's not going to work.
You need a Consult I adaptor with the 14-pin plug. See our website for examples.
https://nisscan.com/NDSI/index.php?content=supportedadaptors
> to work.
> examples.
All site sorted thanks.
Ended up ordering from stahl
> to work.
> examples.
