ConsultBT_v2 and NDS1
Has anyoen been successful connecting the new version of ConsultBT from Track electronics to NDS Android? Seems to connect but then disconnects and will not reconnect until the phone gets rebooted. Any ideas would be great. Samsung S6 Edge with Android 7.x running NDS for Android. Also, tried using NDS1 for Windows (Windows 10) with no luck connecting either.
Re: ConsultBT_v2 and NDS1
Im having same problem. Pease post if you find any info il keep digging. Tryed galaxy tabA, galaxy s7 active, and galaxy s9+. Actually when i was using torque pro with yhe obdlx in my chevy colorado it also dropped connection mid drive. Im woundering if its a sleep issue with the device
I find that once I turn the car off, I have to kill the app and restart it after the car is running for it to work again. I have the screen always on as well, because if it turns off it will disconnect.
