NO communication to Tcm
Hi, I have used the adapter to communicate with the ECM, BCM and SRS but it seems that I cannot connect to the TCM. Is the Adapter able to connect to the TCM? I have a 2003 Nissan altima 2.5SL .
Re: NO communication to Tcm
According to the service manual your TCM uses DDL protocol (Consult I) for diagnostics. You will not be able to connect to your TCM with NDSII. See attached.
[attachment=0]Altima AT.pdf[/attachment]
- Altima AT.pdf
- (32.81 KiB) Downloaded 576 times
