Hi.
i have bought the ELM327 ( interfuse ELM327 - ELM327 v1.5 )
for my Nissan 350z VQHR
and use the NDSIII App not the light one.
But i cannot use it :/
i am connecting the ELM to the OBD port. Key second position. Starting the App. becoming Infos (Apapter Name Adapter version ECU typ ECU no) but not seeing any Inofs in the Data display. after 3 seconds becoming an Disconnect ...
Any suggestions?
Bjorn
Nissan 350z VQHR Not Connecting
- 3.jpg (127.42 KiB) Viewed 31698 times
- 2.jpg (127.16 KiB) Viewed 31698 times
- 1.jpg (125.8 KiB) Viewed 31698 times
Re: Nissan 350z VQHR Not Connecting
Good Morning,
so I tryed it again. And it still would not work (Samsung S6 Buildnumber NRD90M.G920fxxs5eqfc android 7.0 Baisversion: G920fxxu5eqd4). So i Tryed my Tablet (Lenovo yoga Tab) with the NDS Lite an it worked perfektly. Okay, till i hade to connect to the Internet.
Here are the Log Files from my S6:
Greatings
Bjorn
Greatings
Bjorn
- NDSIIIdebug20170803_071857.log
- (1.17 KiB) Downloaded 3324 times
- NDSIIIdebug20170803_071755.log
- (1.07 KiB) Downloaded 3283 times
I had a look at the debug files. Your adapter is freezing and not sending anything after the ECU number. One of the logs didn't even get the ECU number.
Are you using the same adapter with the Lite app? Can you send the debug file from the Lite app?
Here are the Log's from my Lenovo yoga Tab..
The Sice ist bigger an 200KiB i will send it to you via Mail.
