Cannot connect to abs
Help needed please I can read ecm and other listed but not the abs and they are the problems I'm having on my e51 elgrand
Re: Cannot connect to abs
What active ECU IDs do you get when running the "Find ECU" function?
It could be that the ABS ECU is using the older Consult I protocol for diagnostics.
Hi tom
The active ecu ids are 10,18,58 that's all it picks up
Many thanks Mark
Many thanks Mark
The ABS ECU has id 28, so it looks like it;s not coming up.
Try changing the "Ini Timer Offset" value (to positive and negative values) and try connecting every time you make a change.
