NDSIII for Android released
Discussions related to NDS III Android app
The Nissan DataScan III for Android is intended for newer Nissan cars equipped with 16 pin OBDII connecter and use Consult III protocol over CAN. Those are usually cars build between years 2007 and now.
A list of cars that the software has been tested on is located on the Supported Vehicles page. The list is by no means comprehensive and is constantly being updated as new vehicles are tested.
The NDSIII application supports both, petrol and diesel cars. It communicates with the engine ECU using Consult III protocol. It uses the same communication protocol as the dealer diagnostic tool. This protocol is far more comprehensive than the generic ISO15765 protocol. It has following functions: Data Display, Data Logging, Self Diagnostics, Clear Self Learn, Idle Air Volume Learn and Dash Display with customizable gauges.
A Bluetooth diagnostic adapter is required to connect to the car. This app is design to work with adapters build on the popular ELM327 chip. They are very well priced and available from many Internet suppliers or eBay. For a list of tested adapters please visit the Supported Adaptors page.
The NDSII app can be downloaded from Google Play store NDSIII for Android https://play.google.com/store/apps/deta ... niii&hl=en.
[attachment=0]DashL.png[/attachment]
Dash tab
Dash tab
seb.racing
Re: NDSIII for Android released
Post by seb.racing »
nice ;)
nds3 is planned for pc?
RobPhoboS
Post by RobPhoboS »
Can the ABS module be activated via this updated version ?
No. The app works with ECM only.
RobPhoboS
Post by RobPhoboS »
(excuse the ignorance here!)
Is this just something that cannot happen via this kind of software?
It can be done. It just hasn't been implemented.
kurniawandicky
Post by kurniawandicky »
Hallo...
Thanks for a great application...
the only one that can talk to my car's ecu so far.
I have nissan grand livina with engine HR15DE.
Now, I need to change Ignition timing correction.
This app can do that?
What year is your car?
Sorry, this app can not do timing correction. We are working on a Windows PC software that will but its still a long way away.
kurniawandicky
Thank you for reply,
Car years 2013, I use cheap ELM adapter.
Hope someday can do timing correction change..
cheers
coolpix99
Post by coolpix99 »
Does NDSIII support Nissan Juke (MR16DDT)? Particularly the Transmission Temp and Intake Air Temp 2 (before throttle body)
Thank you.
Ben
