ini failed
mastrZ
ini failed
Post by mastrZ »
just got my bluetooth adapter from the recommended uk supplier..
I have a Droid turbo x running on the 5.1
plugged the BT adapter in..
paired to it..
opened up NDSI for the android, connected to the HC-05 adapter..
says connected, but immediately has a status of: ini failed
any thoughts or help here would be great! really looking forward to utilizing this daily.
thanks in advance,
-Matt
Jason
Re: ini failed
Post by Jason »
Check if you are getting the clock signal on the adapter CLK pin. It should be reading about 154kHz.
If you are not getting anything return it to the supplier or fix it.
Jason
Re: ini failed
Post by Jason »
Fix from the supplier looks like the attached pic. It's the white wire.
A PCB fix will be implemented in the next production run.
Bluetooth Consult I clock signal fix
zitko
Re: ini failed
Post by zitko »
Hello, I got "mini ELM327 v1.5 OBDII Bluetooth Adapter". On my phone I also install NDSI LITE app. When I try to connect via app to the adapter, every time drop the connection status in app "ini failed". What can be a issue :?:
amdeleon23
Re: ini failed
Post by amdeleon23 »
Im also getting this but im using the ftdi usb. Can anyone help us address this problem? I really need to use this thanks.
Re: ini failed
NDSI app is not designed to work with ELM327 Bluetooth adapters. Try NDSII or NDSIII depending on the model of your car.
niko99
Re: ini failed
Post by niko99 »
I am trying to connect to my nissan almera n15 (ga16de) with the bluetooth adapter (not DIY)
but I get the "Ini failed" message...
Any suggestions how can I fix this :[?
Re: ini failed
niko99 wrote:
> Hi,
> adapter (not DIY)
What adapter are you using?
niko99
Re: ini failed
Post by niko99 »
What detail do you need exactly?
It looks like this one:
http://home.exetel.com.au/nds/NDSIA/pic ... 67x363.jpg
niko99
Re: ini failed
Post by niko99 »
Anyone :|?
