Hello
I used my NDS1 on Primera GA16DE to adjust the ignition timing
when I active "Base Idle Adjustment" the engine speed drops to 450tr/min
an idea?
thank
Base Idle Adjustment = engine speed falls
Re: Base Idle Adjustment = engine speed falls
Adjust the idle speed with the throttle crew. See the PMS page for some hints http://www.plmsdevelopments.com/sr_setu ... dle_adjust
yes, the engine works very well
Ignition timing and idle regime are set
I do not understand this phenomenon
