Primera P12 ABS connection
Veijjo
Post by Veijjo »
does anyone know if NDS2 software is compatible with Year 2005 Primera P12, 2.0 petrol(QR20DE) abs unit?
I have tested the unregistered version of software but when I try to connect to the abs section, the program announce "no connection" and the buttons remains greyed also there is ECU PART NUMBER XXXXX-XXXXX?
I can only connect to OBD2-section and ECM-section.
PS.
Sorry for my poor english, I´m from Finland
-Veijjo
seb.racing
Re: Primera P12 ABS connection
Post by seb.racing »
BCM, TCM, SRS does it work?
Veijjo
Post by Veijjo »
no they doesn't work. Program says "not connected" to all of them, BCM,TCM,SRS,ABS,
Active ECU Test found 3 active ECU's( Id 10, Id 42, Id 71)
I changed Ecu Id's to those numbers which I got from Active Ecu test and I did get connected to BCM( ecu part number remains ##########, software version 0x710) , also I get connected to TCM (Ecu 31036-BA060, software 0x00) ,ABS connected (Ecu ########, software 0x710), SRS connected (Ecu ######, software 0x71), ECMD (ecu 23710-ba060, software 0x00)
seb.racing
hi
Unfortunately, I can not help you
send e-mail to Tom, he must know your problem ;)
Veijjo
Post by Veijjo »
Do you have his email address? I can't send him PM.
Thanks,
-Veijjo-
The ABS ECU Id is 28. This ECU is not responding when you try to search for active ECUs. Only ECUs 10, 42 and 71 respond.
Your ABS could still be using the older Consult I connection (DDL1). This could be confirmed by checking the wiring diagram for ABS ECU. Would you have one available?
Veijjo
Post by Veijjo »
I have Electronic service manual but I'm not sure where in this manual I could find the wiring diagram for ABS ECU.
I found wiring diagram for ABS would it be helpful?
-Veijjo-
The ABS ECU wiring diagram should be in the BRC section.
Veijjo
Post by Veijjo »
I found these following pictures ( see the attachments) of ABS wiring in BRC section, are these any helpful?
Thanks,
-Veijjo-
Abs Wiring 3.pdf
(37.66 KiB) Downloaded 482 times
Abs Wiring 2.pdf
(43.1 KiB) Downloaded 441 times
Abs Wiring.pdf
(51.09 KiB) Downloaded 459 times
