Has anyone had any luck running NDS 1 for android with the LG Lucid 2 VS870 phone. I have found it is quite a challenge to get it to work. When I plug into the A's Development consult plug which does have the FTDI chip in it, the phone says NO FTDI USB DEVICES FOUND. I don't even get a charging signal for the phone. Has anyone had this problem and figured out a way to fix it? Are you SUPPOSED to get a charging signal when plugged into consult with the key on? Does anyone have any idea as to why my plug cannot be found on my Droid when it works flawlessly on my laptop? My OTG cable is a true host cable with a female usb on one side and the male micro on the other side. Can ANYONE advise please???
Thanks!!!!!
LG Lucid 2 VS870 won't work
Re: LG Lucid 2 VS870 won't work
After much research and testing, it appears that the LG VS870 does NOT have usb host capabilities. Hooked up to my Samsung Galaxy 4, everything works flawlessly.
