Nissan DataScan I ver 1.61 now available
New software releases and other announcements
Changes and additions in Revision 1.61:
•Air Bag ECU support
•Support for most Diesel engine ECUs
•Diesel specific DTCs
•Diesel specific Active Tests
•Additional petrol DTCs
•Additional Active Tests
•Auto test for supported parameters and registers
•Trip computer function
•Free use of Dashboard, Data Replay, Log Analyser and Trip Computer functions (no registration required)
Download Nissan DataScan I ver 1.61: http://home.exetel.com.au/nds/NDSI/down ... 201_61.zip
seb.racing
Re: Nissan DataScan I ver 1.61 now available
Post by seb.racing »
install ;)
I noticed with this release
I can not change "ECM data display" if I'm not connect to the vehicle
I find my problem nds.debug
Windows vista is blocking :evil:
on my 2nd computer with Windows XP it works
That is correct. You can not change the Data Display settings unless you are connected to the car. This version checks for available parameters after connecting. It will only let you monitor parameters that are supported. No more gauges with all "0" in Data Display.
