Nissan DataScan II ver 2.52 released
New software releases and other announcements
Nissan DataScan II ver 2.52 has now been released. The main changes are:
•Support for generic "dumb" OBDII adaptors. ELM adaptors not supported.
•BCM Data Display function
•Fixed check sum bug
•Support for diesel ECUs (ECMD) - tested on Almera YD22DDT
•Additional ECM parameters including base fuel schedule
•Ignition Timing Active Test
•Improved reliability of Idle Adjustment and Timing Adjustment functions
•Software activation required for full functionality
•Connection to ECU can be tested with unregistered software
•Microsoft .Net Framework 3.5 required
If you do not have an account for activating NDSII software please contact us on nissandatascan@yahoo.com with a proof of purchase from our authorised distributor.
