Update from 2.5.4 to 2.5.6 plus an inquiry
ozstar
Post by ozstar »
I have had NDS since 2019 and now just see my 2.5.4. has update to 2.5.6.
For me to update do I just install it ? Does it overwrite the 2.5.4. or do I install it as a separate program ?
I have a Nissan Elgrand E51 (VQ35DE) and want to use it. I have the USB dongle and 2.5.4.connects just fine.
I use Win 10 with a Surface Tablet.
I have a miss in the engine and want to check. It says no error codes.
On the Elgrand UK site it has been suggested I give them the results of the following.
More relevant fields would be RPM, intake air flow reading, LTFTB1 LTFTB2 STFTB1 STFTB2, Front O2 sensor B1, Front O2 sensor B2, Rear O2 sensor B1, Rear O2 sensor B2, injector duration B1, injector duration B2.
Does 2.5.6. do this and is the method in the manual ?
EDIT.
I have installed 2.5.6. but not connecting so still using 2.5.4. which does.
Thank you
