Access all Control Module on latest Nissan Micra K11
nokiahelp
Post by nokiahelp »
I bought a black VAG K+CAN adaptor to use NDSII on my Micra K11 from 2000/2001 (mk4), and tried the trial version to see if it works.
The connection to the ECM is OK, but not to others control module (ex. SRS because my car has airbags).
I guess only the ECM uses Consult II protocol and maybe NDSI would work for others control module, but Consult I adaptors doesn't have the same connector shape (OBD2).
Is there a way to access others control module?
Jason
Re: Access all Control Module on latest Nissan Micra K11
Post by Jason »
You can get the Consult I adaptor with OBDII plug from ECUTalk https://www.ecutalk.com.au/interface.aspx
Not sure which protocol the SRS on your car is using. You can usually tell by reviewing the wiring diagram but it has to be for your specific model car. If the SRS ecu has Rx and Tx pins then it would be using Consult I (NDS I).
