Bit higher idle & P0175
Posted: 07 Feb 2023, 00:38
by maruku
Hope someone could help me. I am trying to figure out why after a longer drive I got P0175.
It's a VK45DE engine.
Symptoms that I can tell are rich A/F smell from exhaust, idle RPM won't go to specified 650 +/-50 RPM but rather wobbles around between 738 and 800.
I initially assumed I might have a vacuum leak but only bank 2 is complaining.
Attached a log of a static run, I can see that when I hold the engine at 2k RPM, bank 2 sensor starts measuring between rich and lean but bank 1 stays lean most of the time.
Any pointers greatly appreciated, I will try to do a leak test to make sure I have no vacuum leak.
Might do another log file during warmup to get a better idea what is going on, any suggestions for which data I should collect?
