Idle Air Relearn problems
gkeylow
Post by gkeylow »
Im running Datascan II obviously (v 2.54) I have a ‘06 G35. But for some reason, when I run said relearn; It never completes. It always runs to the default stop time of 5000.
And this is after ECU reset, Accel Pedal & Throttle Valve.
Note: I had to change valve cover gaskets, wanted to make sure everything was kosher since I had to fully removed the intake, plenum, etc. It’s running fine, prob don’t need to have it relearn; but this is the only thing that doesn’t/isnt working with the software.
Thanks in advance for your help
gkeylow
Re: Idle Air Relearn problems
Post by gkeylow »
https://nisscan.com/phpBB3/viewtopic.php?f=5&t=325&sid=ffdc4ddf37eebc1cfaeeccc9f220b50a
Just found this post, I’ll run through it and get back to house guys
