Im running Datascan II obviously (v 2.54) I have a ‘06 G35. But for some reason, when I run said relearn; It never completes. It always runs to the default stop time of 5000.
And this is after ECU reset, Accel Pedal & Throttle Valve.
Note: I had to change valve cover gaskets, wanted to make sure everything was kosher since I had to fully removed the intake, plenum, etc. It’s running fine, prob don’t need to have it relearn; but this is the only thing that doesn’t/isnt working with the software.
Thanks in advance for your help
Idle Air Relearn problems
Re: Idle Air Relearn problems
https://nisscan.com/phpBB3/viewtopic.php?f=5&t=325&sid=ffdc4ddf37eebc1cfaeeccc9f220b50a
Just found this post, I’ll run through it and get back to house guys
Did you ever get the software to successfully do the Idle Learn function? If not, how did you fix the problem, if it is fixed?
