Trouble connecting to any ECU 350z 04
Nelsonfsv95
Post by Nelsonfsv95 »
Hi, Im having troubles connecting to ecus, i can only fully connect to the srs ECU, when clicking on ABS for example it founds the ECU, i can hear 2 relays clicking and the it stays on get params.
On the ECM he can find the ECU, the version its 0x00 and states version on the left bottom and stays like that, I already tryed changing the time from -5 to 5
On the obd2 functionnit fully connect but when i try to start the data live it gives an error, the cable im using is an kkl 409 if anyone can help !!
Thanks !
Re: Trouble connecting to any ECU 350z 04
Do you ever get the "Connected" message in the bottom left corner when connecting to the ECM?
What version of NDSII are you using?
Nelsonfsv95
Hi tom, no it stays on version, Im using the NDS 2 2.55
Nelsonfsv95
Tom i think i made it work, i had to give admin permission to the aplication and how its working !
Thanks anyway !
