problem with the connection of the KKL Vag-Com 409.1
szymon_jurowski
Post by szymon_jurowski »
Hello. I have a problem with the connection of the KKL Vag-Com 409.1 adapter to the Nissan Data Scan II program.
The program "sees" the adapter, but connect failed is displayed when it connects to the car's controller. How should I deal with this problem? Adapter set to Generic adapter My car is Nissan Micra K12 2008 Polift
Re: problem with the connection of the KKL Vag-Com 409.1
Try searching for active ECUS. Use the Find ECU function under Settings->Communication. You should get some active ECU IDs. If nothing comes up your adaptor might be faulty.
