ECM connection
Posted: 09 Oct 2020, 14:24
by gn22
HI,ECM connection failed, but TCM, ABS, SRS, connection good any idea please thank you.
Re: ECM connection
Posted: 09 Oct 2020, 17:44
What's the engine model you are trying to connect to?
Re: ECM connection
Posted: 10 Oct 2020, 00:52
by gn22
VQ40DE ,2008 Nissan pathfinder petrol engine v6,thanks
Re: ECM connection
Posted: 16 Oct 2020, 00:08
You should be able to connect to the ECM.
Try connecting from the OBDII tab to confirm there is no issue with comms to the ECM. If that works, try adjusting the Ini Timer Offset value under Settings->Communication.
Re: ECM connection
Posted: 17 Oct 2020, 05:36
by gn22
Hi, I try that but does not work, adjusting the Ini from -5 to +5 nothing, thanks
