Cannot connect to abs
Markwilky
Post by Markwilky »
Help needed please I can read ecm and other listed but not the abs and they are the problems I'm having on my e51 elgrand
Re: Cannot connect to abs
What active ECU IDs do you get when running the "Find ECU" function?
It could be that the ABS ECU is using the older Consult I protocol for diagnostics.
Markwilky
Post by Markwilky »
Hi tom
The active ecu ids are 10,18,58 that's all it picks up
Many thanks Mark
Markwilky
Post by Markwilky »
Tom are you there
The ABS ECU has id 28, so it looks like it;s not coming up.
Try changing the "Ini Timer Offset" value (to positive and negative values) and try connecting every time you make a change.
