Will the dell venue pro 11 run this software
Discussions related to Nissan DataScan I Dash (NDSID) Windows PC software.
mrsanchez925
Post by mrsanchez925 »
I am looking into purchasing a dell venue 11 pro as a carputer to run Datascan.
before purchasing I wanted to be sure it would be able to run the Nissan Datascan dash program.
It is said to rival the resurface pro 2 which is essentially a laptop without a keyboard. As well as runs a TRUE windows 8.1 rather then the tablet version of windows.
Here are the specs.
Display
10.8 in IPS Full HD (1920 x 1080), 10-finger multi-touch support
Processor
Intel Atom Z3770 1.46 GHz up to 2.39 GHz
Memory
2GB LPDDR3 1066 MHz
Hard drive size
64GB SSD
Operating system
Windows 8.1
PC type
Tablet
Optical drive
None
Media drive
Micro SD card reader (SD/SDHC/SDXC)
Audio
Integrated audio
Video
Intel Gen 7 Graphics
Ports
1 USB 3.0 • Mini HDMI • Headphone output/Microphone input combo • Keyboard connector port (attachable keyboard sold separately)
Battery
3-cell (up to 10 hours)*
Camera
2 MP HD webcam front, 8 MP back
Wireless
802.11b/g/n (Miracast enabled)
Bluetooth
Yes
Dimensions
11.72 x 6.96 x 0.40 in (297.68 x 176.78 x 10.16 mm)
Weight
1.68 lbs (0.76 kg)
Much thanks!
mrsanchez925
Re: Will the dell venue pro 11 run this software
Update .
Datascan will run on any tablet that uses a full windows os.
If the tablet you choose comes with a micro USB and not a full size USB port , you'll need to buy an OGT cable in order for it to work .
I'm currently running nds on my dell venue 8 pro.
