I need to put my 300zx into hicas diagnostic mode so that the rear wheels steer with the front wheels.
there is a method of doing it by turning the steering wheel 5 times then pump the brake pedal 5 times but I just cant seem to do it.
is there a way please of using the datascan software to enter this mode so I can bleed the rear rack.
all the instructions I have downloaded do not mention anything about the hicas.
Hicas diagnostic and bleeding.
Re: Hicas diagnostic and bleeding.
hello,
In HICAS mode, you have a "Driving simulation" function, this function allows you to turn the rear wheels with the vehicle at a standstill, however this function does not work on electric HICAS.
