VAG-K + CAN fails. Is there a Bluetooth alternative?
Posted: 02 Jul 2020, 10:58
by GaryJ
I have a 2007 350z HR and need to address the ECM.
I have installed NDS111 on two laptops Win 10 and Win 7.
Purchased from Aust. supplier, the recommended Commander VAG-K +CAN cable,( it only supports WIN 7); however Bitdefender found part of the software corrupted. Any attempt to connect NDS to the cable causes blue screen shut down. ( at this stage cable is not connected to the vehicle).
I have read one Skyline blogger who gave up after buying 3 useless cables; but he claimed success with a PP2145 Bluetooth interface bought from Jaycar.
Has anyone found this or another alternative that works. Also welcome comments on my blue screen crashes.
Re: VAG-K + CAN fails. Is there a Bluetooth alternative?
Posted: 15 Jul 2020, 00:44
by Jason
Most of the Vag K+CAN adaptors use the FTDI USB chip. Have you tried an FTDI driver?
https://www.ftdichip.com/Drivers/VCP.htm
Im not aware of any Bluetooth Vag K+CAN adaptors. The Jaycar adaptor would probably be an ELM327 model which is not compatible with the NDSIII Windows PC software.
Posted: 03 Aug 2020, 11:59
by GaryJ
thanks for the reply. Im up and running with the android version. Cheers
