Hi everybody am glad to be here,
I downloaded the lite version of NDS3 on my Android 4.4.4, ans i use an Elm327 v.1.5 bluetooth. After pluged into OBD2 plug, paired and fresh started the App... it get firstly connected and giving info on ECU, adapter name etc, then quickly it drops the coonection showing a simple CONNECTION LOST pop up! After that, if I press the connection key it wont reconnect anymore as long the adapter will be re-plugged new and app restarted, at that point it connects successfully and again to fail a second later. My car is a 2012 Nissan Teana (j32) vq25de, here in Thailand. I wonder if the app its acting like this because it meant to be like that so I have to buy the paid version or we do have another kind of problem?? Please any advise will be very appreciated...
Regards, Alex
NDS3 lite fails
Re: NDS3 lite fails
hi there
i also downloaded the lite version as i want to test it and make sure it works, and then i would like to buy the full version. (i like to contribute to development of this app)
however it doesnt want to connect/talk to my t32 2016 x trail
i know it can see and connect to the bluetooth elm327 obd connector
but i get the following messages at the bottom
"get params failed"
"get regs failed" and
"set diag session failed"
obviously i can use or see any other functions either.
Any ideas on how to get this to work?
"get params failed"
- Screenshot_20170125-104153.jpg (171.92 KiB) Viewed 6409 times
- Screenshot_20170125-104116.jpg (173.7 KiB) Viewed 6409 times
- Screenshot_20170125-104109.jpg (175.3 KiB) Viewed 6409 times
Re: NDS3 lite fails
...I still in the hope to get some tips as well...ready to download and pay for the full version!
Re: NDS3 lite fails
i've noticed versoin 1.3lite is up in the play store.
still cant connect to my x trail though
Re: NDS3 lite fails
thanks for the info...i will update the app and see if i get any chance to connect...will keep you posted!!
Re: NDS3 lite fails
hi, updated NDS3 to v1.3 but still can not connect at all.... I don"t know what else i can do, i wished to get some tips here but it still just a wish. Also was thinking to download NDS2 but if i right understood that will only work for Laptop and can't be connected via ELM327 bluetooth, which is the only interface i got for now... it wouldn't work right?
Re: NDS3 lite fails
Can you generate and send us the debug file?
Go to the NDSIII Lite app Preferences and activate the "Save debug file" option right at the bottom and restart the app. Try to connect to your car a few times then disable the option. This will save a text file in Download/DebugLog folder on your device. Email it to nissandatascan@yahoo.com.
Re: NDS3 lite fails
I have purchased NDS 3 (v 1.3) and the application is crashing on my Android 4.4.2 Tablet.
can anyone help with a solution please.
