Nisbie ini failed error R32 GTR ECU + Nistinue
Discussions related to Nissan DataScan I software (NDSI) for Android
Fallen
Post by Fallen »
Hey all,
I’m getting an INI Failed error on the lite Android app.
The Nisbie model is BT3V24AB-2273 and my R32 GTR has an ECU with a Nistune chip. It connects (green light) but then the error.
I tried the windows app to but no luck either.
Any help would be greatly appreciated.
Re: Nisbie ini failed error R32 GTR ECU + Nistinue
The Ini Failed error message indicates there was no reply from the ECU. Do you know if the Consult port in your car works after the Nistune upgrade?
The fact that you can not connect with the Windows software either would suggest there is a wiring/ecu issue.
Fallen
Post by Fallen »
Thanks Tom,
I'll check with my mechanics to see if the consult cable works.
